rear tires
Rick
rear tires
Postby Rick » Mon Dec 19, 2011 10:18 pm
May be a dumb question but im wondering why dont you use just bottlecaps on the rear and shit old hard tires for drifting? Seems like putting wide rears is counter to what you want and just takes lots more power to get the same results...
Re: rear tires
Postby Nsquared97 » Tue Dec 20, 2011 5:53 pm
I don't know if you have ever driven much in the snow, but the concept is the same. It is way easier to slide around with snow tires on (lots of grip) because when you want the rear tires to 'bite' and regain traction, it is way easier when they have lots of grip. Same with drifting, wide sticky rear tires make it much easier to control the rear end.
Re: rear tires
Postby Yoshi » Tue Dec 20, 2011 5:56 pm
You want the stickiest tires you can still manage to drift with. Crap tiles will just cause you to drift slowly.
But the main reason not to use bottle caps is the terrible selection of tires. Stock tire size is around 195/65/14. That's HUGE sidewall. After a certain point of suspension work, the tires are flexing and not the suspension. Even then, on transitions, the car will shift but the tires won't. It causes a kind of "snap oversteer".
Basically, for drifting, you want the smallest sidewall possible and the best tires you can still drift on.
Rick
Re: rear tires
Postby Rick » Tue Dec 20, 2011 7:39 pm
I see said the blind man. Thanks.
Do you look for harder compound for the rear?
Re: rear tires
Postby Yoshi » Tue Dec 20, 2011 7:41 pm
eh... kinda. I run federal 595s most of the time. kinda hard. last a long time. Smoke great. Ancient Japanese drift secret.
Re: rear tires
Postby Nsquared97 » Tue Dec 20, 2011 7:56 pm
Yoshi wrote:eh... kinda. I run federal 595s most of the time. kinda hard. last a long time. Smoke great. Ancient Japanese drift secret.
Hahaha I reread this with a oriental accent, made me lol.
