Help diag this problem on my E30
Re: Help diag this problem on my E30
Postby Yoshi » Thu Oct 01, 2009 12:15 pm
well technically no rear sway should give you more rear traction not less. But it should help keep a good contact patch on both sides mid corner and smooth out transitions. So goes the theory. I might test it out at the track next event. with and without the bar.
madmaverick
Postby madmaverick » Mon Oct 05, 2009 8:38 pm
Yoshi wrote:well technically no rear sway should give you more rear traction not less. But it should help keep a good contact patch on both sides mid corner and smooth out transitions. So goes the theory. I might test it out at the track next event. with and without the bar.
That shouldnt be too hard, just remove the links and go for a run.
Postby Yoshi » Tue Oct 06, 2009 12:42 am
yep yep lookin forward to it.
