Yoshi drifting 1/23/10
Post by Yoshi » Mon Jan 25, 2010 4:02 pm
This is the crash that killed the trailing arm. You don't see the spin after this but you can see what happened. It's a splash not smoke on the front btw.
broken car :(
Re: Yoshi drifting 1/23/10
Post by Yoshi » Mon Jan 25, 2010 5:45 pm
First run of the day
third run of the day. And I guess my last of the day :(
Post by M20_fever » Mon Jan 25, 2010 6:03 pm
that last spin looks very Dukes of Hazard, I approve. :)
Post by Yoshi » Mon Jan 25, 2010 6:06 pm
It's a rough transition from outfield to infield. I've never been able to get it in my own car (funny I can do it in others). If you hit it too fast, you spin. Too slow, you don't rotate enough and just straighten out. I need to learn the long slide.
madmaverick
Post by madmaverick » Mon Jan 25, 2010 6:48 pm
Yoshi wrote:It's a rough transition from outfield to infield. I've never been able to get it in my own car (funny I can do it in others). If you hit it too fast, you spin. Too slow, you don't rotate enough and just straighten out. I need to learn the long slide.
Looks like a good dip. Throttle modulation and handbrake should get you through. Scrub speed with the handbrake and left foot (set your angle), then ease back into the throttle after the bump. You want to make sure your not over-rotated when you hit that transition.
Post by Yoshi » Mon Jan 25, 2010 7:08 pm
I was going to try that. but I still have a shattered ebrake so my car goes "kachuka kachuka" at low speeds unless I leave the Ebrake up 1 click :)
Oh the list of shit I need to fix.
Post by M20_fever » Mon Jan 25, 2010 7:28 pm
you should make a list of what you don't need to fix, probably shorter. :)
Post by Yoshi » Mon Jan 25, 2010 7:38 pm
The steering wheel is on pretty well.
Post by M20_fever » Mon Jan 25, 2010 7:58 pm
always a good thing!
madmaverick
Post by madmaverick » Mon Jan 25, 2010 11:06 pm
Yoshi wrote:The steering wheel is on pretty well.
Minus the loose nut behind the wheel.
*chuckle*
Post by Yoshi » Tue Jan 26, 2010 12:42 am
:lol:
Post by ten2doyle102 » Tue Jan 26, 2010 2:23 am
*chuckle*
Nice! :D That was well played!
Post by ten2doyle102 » Mon Feb 15, 2010 3:42 pm
When is the next event?
Post by Yoshi » Mon Feb 15, 2010 3:47 pm
march 14th. Still got to do my subframe and new mani. Sadly the snow is killing me.
Post by ten2doyle102 » Mon Feb 15, 2010 3:49 pm
How much have you gotten recently?
