| Author |
Message |
Joined: Fri Feb 27, 2009 1:28 pm Posts: 9212 Location: Northern IL
 I F*cking HATE Civics!
at least the one I'm working on right now. Alternator needs replacing, easy right? Should take about 30 min tops, so why am I going on 3 hours? Because when the alternator failed it seized completely it bent the pivot bolt on the bottom inside the bolt sleeve of the alternator. I've been hitting that damn thing with an air chisel and pounding on the end to no avail, now I'm waiting on a second set of hands to hold the 4' bar I have against the bolt end while I beat it like a bad stepchild, hopefully that persuades it out...
_________________ Midwestern Councel C Prepared class champion 2012 North Suburban Sports Car Club C Prepared class champion 2012 HSAX Instructor GET YOUR E3P GEAR HERE: http://www.cafepress.com/e3pgearshop
| Wed Jul 29, 2009 7:32 pm |
Joined: Fri Feb 27, 2009 5:17 pm Posts: 5191 Location: Appleton, WI
 Re: I F*cking HATE Civics!
You just don't know what your doing....  I am just kidding. How long was it running with it seized??? I can't believe it bent the bolt! I had a seized alternator (my own fault for that.... ) and when we started it, sure there was alot of squealling, but the bolt came right out. I feel your pain though....try working on the suspension...
_________________ 750il-318is SIG by ten2doyle102, on Flickr
| Wed Jul 29, 2009 7:37 pm |
Lames
Joined: Mon Mar 02, 2009 2:38 pm Posts: 1566 Location: O-HI-O
lol, simply jobs. Ya sometimes simple just isn't simple.
Last oil change I did (more or less helped with when the person working on it got pissed and left it as is.) involved oil filter strap wrench, pry bar, hammer and vice grips. Wasn't just a fast job either. Good luck!
_________________
| Wed Jul 29, 2009 7:39 pm |
lol, thanks. It better come out, next stop is grindertown.
When the alternator seized the belt was tight enough to stop the engine dead in it's tracks, that, I think, is the moment the bolt bent.
| Wed Jul 29, 2009 8:09 pm |
HOLY CRAP! That's insane! That belt had to be like a fricken rubber band!
| Wed Jul 29, 2009 8:11 pm |
yeah the belt was shot too. Finally got it out with the help of a sawzall and cutting disk.  Runs like a top now.
| Thu Jul 30, 2009 12:51 am |
Well thats good!  Where theres a will....theres a way!
| Thu Jul 30, 2009 2:29 am |
Joined: Thu Feb 26, 2009 7:47 pm Posts: 7085 Location: North VA
grinder FTW! but things like that are why I had stitches in my hand
_________________ Status: HG repair. 488wtq though!
| Thu Jul 30, 2009 12:10 pm |
nah, it was safe and I was protected. Got started on my truck early today, upgraded the rear brakes to 1 ton units and had the drums turned. Tomorrow I need to lay some fiberglass on my boat hull to repair some damage, then it's fishin' time.
| Fri Jul 31, 2009 12:53 am |
Nice! Do you fish quite alot???
| Fri Jul 31, 2009 2:20 am |
Lames
I want to fish now. :'(
_________________
| Fri Jul 31, 2009 2:27 am |
beemnmatt
What kind of fishing do you do? Small mouth, Large Mouth? do you guys have Pike up there? BTW I got a P chip for my e30 and it took all the hesitation out I experience at high RPM's. I feels really good! Now onto that Differ....
| Fri Jul 31, 2009 4:16 am |
I fish year round as much s possible, which has been a lot since I got laid off, lol. I live on the Fox Chain O Lakes so we have everything in here, bass (large and smallies) catfish, Gar, Muskie, Pike, all sorts of pan fish, walleye, strippers, ect. Wife pulled this out at our private boat launch couple days ago.  I had one 6" longer than that up to the side of the dock but the guy working the net knocked it off. Last winter someone in my neighborhood pulled a 54" Musky through the ice, still trying to get me one of those.
| Fri Jul 31, 2009 4:25 pm |
I don't see no wedding ring on her left hand budday!
| Fri Jul 31, 2009 4:53 pm |
Nice yosh.....  Dats a big one!  (insert dirty comment here)
| Fri Jul 31, 2009 6:09 pm |
