2012 Midwestern Counsel event schedule
Postby M20_fever » Wed Mar 28, 2012 5:45 pm
The season is fast approaching, so get those finishing touches done and come out and run with us!
HSAX schedule
Wheel to wheel schedule for those of you that love doing bodywork. :)
Registration for the spring drivers school is now open at http://myautoevents.com/pls/mae/frmMain.Show (you need to register then search Midwestern Counsel to see the events list). This is an evening of detailed classroom instruction (Sun) followed by a full day of one on one instruction (Sat) both on track and in the classroom. Each driver is assigned an instructor who rides along on day two, this is a huge resource. $195 for both days, quite a value for beginning drivers!
Re: 2012 Midwestern Counsel event schedule
Postby ten2doyle102 » Mon Apr 02, 2012 4:20 am
I hope to make atleast one of these....
Postby Yoshi » Mon Apr 02, 2012 12:01 pm
pretty much guarantee I won't make any of these :)
Postby M20_fever » Mon Apr 02, 2012 12:59 pm
You better Matt! Yoshi, quite being a puss at use all your vacation and savings to come play with us for a day. :-p
Postby Yoshi » Mon Apr 02, 2012 1:01 pm
One day... when I have money again.
7pilot
Postby 7pilot » Thu Apr 05, 2012 3:01 pm
TMS are fresh out of J stock Bilstein Struts. That slows my plans. :evil: The car has too much straight line speed for the stock suspension on a track.
Maybe Koni have something that will manage the J stock springs.
m
Postby M20_fever » Thu Apr 05, 2012 3:26 pm
Tms told me the same thing, after I placed my order I got the backorder notice. It only took them like 4 days to get mine shipped though. I assume they are ordering them as needed from bilstein.
Another option is to get some bilstein sports and send them to bilstein and get them revalved for the j stock rates. Its $65 per shock to get them valved. If you post a Wtb ad on the forums you can probably get some old bsports for cheap to send in.
The j stock bilsteins are a better design though, shortened up front and inverted in the rear.
Postby Nsquared97 » Thu Apr 05, 2012 6:52 pm
7pilot wrote:TMS are fresh out of J stock Bilstein Struts. That slows my plans. :evil: The car has too much straight line speed for the stock suspension on a track.
m
What Tony said. Although I am sure if you talked to Koni they could set you up with some custom valved shocks that could handle the J-stock springs too.
7pilot
Postby 7pilot » Fri Apr 06, 2012 12:55 pm
Thanks Guys.
I bought a pair of unused inverted rears from a guy last year. I thought I'd buy a complete set for the warranty. Then keep the pair I have for spares.
m
7pilot
Postby 7pilot » Fri Apr 13, 2012 1:27 pm
As you wise ones have predicted, the dampers are supposed to arrive on the 16th.
I picked up a Sparco EVO 2 plus shell for the drivers seat.
The seat back is a little short I think. as the shoulder belt holes are low.
I'm sharing the car this year so the seat will be higher than necessary as My co driver likes to sit closer to the steering wheel than I prefer.
Next time...Recaro.
m
Postby M20_fever » Fri Apr 13, 2012 3:39 pm
Good to hear, you going to try and make the May 5th event at Blackhawk?
7pilot
Postby 7pilot » Sat Apr 14, 2012 1:50 pm
If I can find a good ZF 320(E36 328/M3) and a S52 PS pump in Ia Wi or Il.
Both are bad.
It's been a while since my membership with madison SSC expired. Does one have to be a member?
m
Postby M20_fever » Sat Apr 14, 2012 9:46 pm
you don't have to be a member to come out and run, but you do need to be a member to be in the points race for any given class. What you need a PS pump for? Just delete the PS, I hate how these cars feel with PS hooked up.
