Cheapest source for SFI 5 or 6 point harnesses?
Post by M20_fever » Thu May 10, 2012 3:09 pm
I've found some gforce 5 points for around $60-70 each for the latch style, but I would prefer cam locks. Seems like all the cam lock SFI approved belts start at $150 up. I can't justify spending double just for a cam lock.
Any of you got a good source for cam lock harnesses?
Re: Cheapest source for SFI 5 or 6 point harnesses?
Post by Yoshi » Thu May 10, 2012 3:15 pm
http://www.ogracing.com/car/harnesses-and-restraints
~$150 seems to be the going rate. So worth it though. Latch takes too long to put on.
Lee
Site Sponsor
Post by Lee » Sat Dec 22, 2012 9:48 pm
Get a 6-points. You'll thank me on your first accident. But if you wear a HANS, you'll need a harness with 2" shoulder belts.
noob is good
Dontrusthise30
Post by Dontrusthise30 » Sat Dec 22, 2012 10:51 pm
Not sure if it matters to you, but there are use ones on eBay that seem to be in great condition for 80-100ish
Post by M20_fever » Sun Dec 23, 2012 10:58 pm
old thread, I picked up a set of Sabelt cam lock 5 points.
