318is Ice Racer----- GO!!!
Re: 318is Ice Racer----- GO!!!
Post by ten2doyle102 » Tue Feb 18, 2014 8:34 pm
I think those guys are a little bit of everything.... FVSCC guys tend to error on the side of caution when it comes to events. CWSCC... not so much. They are all about bigger, faster, crazier tracks and cars...
Post by Nsquared97 » Thu Feb 20, 2014 9:07 am
Loving the spoiler on the trunk! Jelly of the studs too man, that has got to be a blast.
Post by ten2doyle102 » Thu Feb 20, 2014 1:18 pm
Thanks!!! That was a quick addition that my friend and I made up quick. We are making more serious now...cause I am adding angle adjuster to it. Lol
Post by ten2doyle102 » Tue May 19, 2015 7:55 pm
So.... I figure why not throw an update on here... it's only been ages since I've done anything on here. Sorry about that.
At any rate... my ice racing e30 has changed a little since I made this post about a year and a half ago....
This was it last year....
Imagefall ventage 14 660 by austin boynton, on Flickr
mmm.... body roll. I wish I could find the picture I had of it actually lifting the rear wheel about 1" off the ground mid corner. Pretty awesome.
Imagefall ventage 14 522 by austin boynton, on Flickr
that's not tire smoke either.... The poor little M42 was quite tired when she got pulled... Basically emitted a full on smoke screen whenever I let off the gas. LOL.
Here's the beast now.... :mrgreen:
Imageshawano autox 5 17 15 (79) by austin boynton, on Flickr
Imageshawano autox 5 17 15 (26) by austin boynton, on Flickr
This winter I took this car to a whole nother level by swapping an complete m50 swap w/ g320 trans & s52 cams/s52 injectors, lowering springs, Billy sports, ST front sway bar, spherical front control arm bushings, delrin subframe bushings and trailing arm bushings, strut bars and a RX7 caliper swap and a fresh set of BFG Rivals. I also did braided lines too and just put in a 255 fuel pump as the stocker wasn't up to the task. All I can say is it was totally worth it. This car is ridiculous on the track now. Before it was obviously slow, had horrible brakes and non existent suspension.
Things I need to work on though...
1) Relearning to drive the car. Totally different thought process on this than before.
2) Needs the Turner Chip to make the most out of the engine mods
3) Need to upgrade the rear brakes to something else... The bias is all goofy obviously and I am locking the fronts all the time.
4) Still has the stock 4.10 LSD diff in the back. Good for Auto-x, bad for everything else. It revs at 4,000rpm at 70mph!
It's funny how things turn out sometimes.... this thing was supposed to be a parts car initially... Oh well. I think in total I have around $3500 invested into this car. :)
Post by 87e30 » Wed May 20, 2015 12:09 am
ten2doyle102 wrote:It's funny how things turn out sometimes.... this thing was supposed to be a parts car initially... Oh well. I think in total I have around $3500 invested into this car. :)
Quite true. I'm strongly considering doing an engine swap on the 87 325e that I bought as a parts car. I only have $500 invested in that so far though.
Post by ten2doyle102 » Wed May 20, 2015 2:02 am
The fun thing about this car is that since its not mint, I can really drove hard without too much care. The swap just makes all the better
Post by 87e30 » Wed May 20, 2015 12:26 pm
Yeah, my DD is FAR from mint. The body on my "parts" car is in so much better shape, but it's got a non-running m20b27 and someone popped the trunk with a crowbar. If I can get that one on the road I can drive my current DD much harder until it falls into pieces.
Post by ten2doyle102 » Wed May 20, 2015 4:53 pm
This e30 was running... Just smucked up. I was gonna use it for parts but decided it would've be fun to race it.
Been thinking about my bias issue with the front brakes, would just going to HP+ in the rear do much, or should I think about stepping up the the hawk blues? Or possibly some other kind if setup?
Post by ten2doyle102 » Mon Jul 06, 2015 8:08 pm
So it was another busy weekend that resulted in me pulling the heart from Icy once again. It's been a long time coming so it's not a big deal. For day one when we installed the motor, we found out the hard way that something was loose and bouncing around in the bell housing. I should have separated the trans from the motor before installing it, but my friend who I bought it from had just installed a new clutch and flywheel so I figured.. why waste the time. lol.
The other reason for the motor pull was to do the steering rack. It's been pretty sketchy for some time, but it finally gave up the ghost after a high speed, off road excursion off the track two weekends ago.
ImageIMAG0238 by Matthew Reade Photography, on Flickr
At any rate, Here's some photos for what I found in the bell housing. Needless to say I was not too happy. I believe the rod to be from a slave cylinder. I know that my friend had replaced the slave when it was in his car and I think he may have lost it in the bell housing when he replaced the old one. I don't know how else it would have gotten in there otherwise. I think the clutch is functionally ok, just beat up. The bell housing took a beating too, but should be good.
ImageIMAG0240 by Matthew Reade Photography, on Flickr
ImageIMAG0239 by Matthew Reade Photography, on Flickr
Anyway, if anyone has a e36 rack for sale, let me know. I really want a z3 2.7L2L, but those are pretty hard to find. :)
Post by Ryki » Mon Jul 06, 2015 10:24 pm
Damn son! I have a nice whole in my G260 right now from something getting punched out of the trans...
Post by ten2doyle102 » Tue Jul 07, 2015 3:52 am
Yeah, I got lucky that that didn't happen.... Lol
Post by M20_fever » Tue Jul 07, 2015 2:11 pm
I need a "new" g260, I wish we could get these things rebuilt for less than another e30 costs...How old is your clutch? Unless it's new I'd replace it while you have the engine out.
Post by ten2doyle102 » Thu Jul 09, 2015 3:44 am
It's new. Only has maybe 1500 miles on it. :(
Normally I would agree with that mind set, but it should be OK. I'll just running as is. :)
Post by M20_fever » Thu Jul 09, 2015 10:38 am
The condition of the cage doesn't really bother me, if it's new it should be fine. It's like putting an ugly dress on a drunk prom date, might look rough on the outside but you know it's good to go underneath. :)
Post by Yoshi » Thu Jul 09, 2015 11:11 am
Yea that definitely looks like the slave bit. This is why all bell housing should have bottom access points. Would make things MUCH easier. But I guess not as structural. Meh. Autos sometimes have them.
Shit works, shove it back on and go. It might be unbalanced though.
