2009 SCCA SOLO RULES.
BMWIS
Post by BMWIS » Thu Mar 19, 2009 5:18 am
http://cms.scca.com/documents/Solo_Rule ... _Rules.pdf
Stock Category E30 autox classes=G stock (all except pre 91 318's)
Street Touring E30 autox classes=STS (non LSD) STX (LSD)
Street Prepared E30 autox classes=DSP (325 all) (318 i/is 16v) FSP (8v 318)
SM=Street Modified
FP=F-Prepared
XP=X-Prepared
BMWIS
Re: 2009 SCCA SOLO RULES.
Post by BMWIS » Thu Mar 19, 2009 5:26 am
Stock Category allows consumables replacements.
Mufflers/exhausts rust out, shocks wear out, air filters, plugs, wires need to be changed.
The one performance modification allowed specifically is a front swaybar.
A typical stock class E30 autox car might consist of Koni sports, (standard replacement) a 25mm IE front swaybar, a performance alignment (there may be a factory authorized procedure for adjusting camber up front, and if so this would be legal in stock), an extra set of wheels and R-compounds.
While not legal here a Euro E30 with the 15x8 weeves, and a freshly rebuilt LSD would actually make a nice GS car.
A fully prepped Stock class car would add a free flowing, light cat-back exhaust, light stock sized wheels, a fresh rebuilt LSD, fresh NGK plugs, K&N filter, performance plug wires, RedLine fluids.
Jack/spare can be removed.
BMWIS
Post by BMWIS » Thu Mar 19, 2009 5:31 am
Street Touring opens up a bunch more allowances. In this case I'll refer everyone to here.
But in a nutshell=springs, swaybars, shocks, camber plates, bushings, light battery, race seats, emissions legal header, CAI, cam gear, class specific maximum width wheels, and street tires......See below for a general idea.
http://www.vorshlag.com/forums/showthread.php?t=5181
Post by Yoshi » Thu Mar 19, 2009 1:56 pm
man.. this thread is so STICKY
BMWIS
Post by BMWIS » Thu Mar 19, 2009 3:45 pm
Street Prepared.
This is my favorite class. Many modifications are allowed, but the really big $$ stuff isn't allowed. This can cut down on the fun factor. But it can also increase fun factor by not placing you against someone with huge $$ in an E36 M3, Evo etc, which is what Street Modified can, and does have in it.
To paraphrase one of the important allowance in Street Prepared.....Update/Backdate.
This has to happen between car models on the same line in Apendix A in the rule book. They are listed as I listed them above in Street Prepared.
What this means is that all E30 325's can exchange equipment with one another. For instance if you are starting out with a 325e, you could swap the I/IS engine for more power. IS models, typically fully loaded, can de-option the car to reduce weight.
There are usually lots of options to reduce weight on a car that has been built for several years.
A quote from the rule book on the subject.
Equipment and/or specifications may be exchanged between
different years and models of a vehicle if (a) the item is standard
on the year/model from which it was taken, and (b) the years/
models are listed on the same line of Appendix A (Street Prepared
Classes). The updated/backdated part or the part to which
it is to be attached may not be altered, modified, machined or
otherwise changed to facilitate the updating/backdating allowance.
Standard factory installation methods, locations, and configurations
are allowed. The updating and/or backdating of
engines, transmissions or transaxles must be done as a unit;
component parts of these units may not be interchanged. Cars
not listed in the Street Prepared sections of Appendix A may not
be updated/backdated until approved by the SEB and published in
the official SCCA publication.
PradaHawty
Post by PradaHawty » Wed Aug 19, 2009 4:18 pm
kewl thanx for the link
Kiss me and i'll see stars ...love me and i'll give them to you
Post by Yoshi » Wed Aug 19, 2009 5:22 pm
anyone want to take a stab at where my car places in this thingy?
Post by ten2doyle102 » Wed Aug 19, 2009 5:39 pm
I'd think something like SM probably. With all the mods you've got, that what I would think.
Post by Yoshi » Wed Aug 19, 2009 5:53 pm
yea still running street tires. I'd prob get the worst times tho. But damn I would look good doin it.
Post by ten2doyle102 » Wed Aug 19, 2009 6:49 pm
I doubt it....You'd be amazed....
Post by Yoshi » Wed Aug 19, 2009 6:51 pm
lol true. I figure if you have enough money to play that high, you probably had enough seat time to spank me. but you never know.
Post by ten2doyle102 » Wed Aug 19, 2009 7:21 pm
My last auto-x....I ran a fast time than a guy in a 911 gt3.....That should put that in perspective for you! :) $3000 car vs $70,000 car.... Porsche should've beat me, but it all comes down the the driver!
Post by M20_fever » Wed Aug 19, 2009 8:55 pm
Yoshi wrote:But damn I would look good doin it.
ten2doyle102 wrote:I doubt it....You'd be amazed....
Yoshi wrote:lol true.
:D
Post by ten2doyle102 » Thu Aug 20, 2009 12:20 am
Well played tony.....well played....
Rick
Post by Rick » Tue Nov 29, 2011 5:04 am
I'm looking over doing one of these events. So it looks like I would have to run "street mod" because:
I have M3 fenders and no power steering? can the M3 fenders be considered flares? Plus I have the 4.1 lsd so not quite sure...
I always wanted to go to a real track and was saving/preparing for that, but the auto x is much more practical cause its only 40 min away vs 3 hours for Firebird track in Phoenix...
Could be fun!
