ponycarman's 1986 325es build
Re: ponycarman's 1986 325es build
Post by Yoshi » Mon Jun 24, 2013 2:11 pm
Might still be under warranty. I have like 6 spare batteries of questionable ability lol.
Post by ponycarman » Mon Jun 24, 2013 2:18 pm
I doubt it. I think I got it from walmart. I have no idea where the papers are for it. I think I got it when i first bought the car. So it is more than a couple years lol. Time flies.
Post by M20_fever » Mon Jun 24, 2013 6:35 pm
do you have a jump box, or charger with 'start' setting?
Post by ponycarman » Mon Jun 24, 2013 6:48 pm
Nah. I'll probably try jumping it off before investing in another battery. Just to be sure.
Post by Ryki » Tue Jun 25, 2013 11:29 pm
Damn that was bad, not as bad as one I did for someone in their 04 cavalier (damn pos small cars) but bleh. Here's to hoping it works out!!
Post by ponycarman » Tue Jun 25, 2013 11:55 pm
I hope it works out too haha.
Post by ponycarman » Sat Jun 29, 2013 6:46 pm
The verdict is, the battery is toast. When we jumped it off it would turn over. When disconnected from the other vehicle it wouldn't even try. Also I think the fuel might have went bad. I know it can sour from sitting. It tried to crank and would start fror a few seconds but it would run horribly rough. Like it was only running on a couple cylinders. Then it would die. So I need to get a new battery and try to drain the tank i guess.
Post by Ryki » Sat Jun 29, 2013 7:58 pm
Woot, super simple stuff but not cheap or easy! Good luck!
Post by ponycarman » Sat Jun 29, 2013 8:12 pm
Thanks. Yeah the battery isn't cheap but its easy to swap. I'm hoping its just the fuel that it the problem. Its the first step at least and it needs to be drained. It looked pretty cruddy when I had the pump out
Post by Ryki » Sat Jun 29, 2013 9:35 pm
I hated relining the tank in my Javelin but it was well worth it, just lots and lots of terrible fuel on me and my face and my skin and in my mouth... I seriously meant good luck :D
Post by ponycarman » Sun Jun 30, 2013 1:57 am
Great haha.
Post by M20_fever » Sun Jun 30, 2013 6:05 am
You can smell if the fuel has gone bad, its a distinct smell thats nothing like fresh gas. How much is in there? Can you just top it off with some premium? If the battery is that dead it could be the cause for the rough running. If the ECU doesn't get full voltage it won't run right. I'd swap in a good battery and try it before going through draining the tank.
Post by ponycarman » Sun Jun 30, 2013 10:14 am
There isn't that much in the tank. Its pretty low. But there is alot of junk in there too so ot probably wouldn't be a bad idea to just drain it anyways. Once I get a new battery I'll try it again to see if there is any difference. I didn't notice any strange smell but I wasn't really looking for it either so I'm not sure. It wouldn't surprise me though. Its been a while since I've cranked it up.
Post by Ryki » Sun Jun 30, 2013 10:17 am
Meh, if you aren't loosing much I would drop it and drain it and clean it, especially since you gotta get the battery and such but Tony is right in that gas that has fouled smells, well, fouled : )
Post by ponycarman » Sun Jun 30, 2013 10:44 am
With all the tank drain plug horror stories, I guess I'm afraid I'll strip it out. There isnt really that much fuel in it. Might try putting a few good gallons in it to see if it makes a difference.
