White 87 325is in NJ
Re: White 87 325is in NJ
Post by M20_fever » Wed Apr 10, 2013 2:05 pm
Lol, perfect mental picture.
Post by AustinR » Wed Apr 10, 2013 10:54 pm
YES!
Ryki wrote:My mind has your car filled with stuff and you just kind of insert yourself into a human shaped mold of randomness...
Lolz. Great description.
Post by 87e30 » Thu Apr 11, 2013 3:05 am
That's pretty much how it was getting.
Post by Yoshi » Thu Apr 11, 2013 11:03 am
Austin... is wrong to have such a large signature.
Post by AustinR » Thu Apr 11, 2013 4:16 pm
I, too, was thinking my sig was getting a touch on the lengthy side. Not my fault though! I can't help the fact that I'm right all the time. 8)
Edit:
There, tried to make it a bit more compact for ya :wink:
Post by Yoshi » Fri Apr 12, 2013 12:00 am
smh
Post by Nsquared97 » Fri Apr 12, 2013 5:32 am
-wuut-
Damnit Austin.
Post by 87e30 » Mon May 13, 2013 12:00 am
Got some new (used) wheels for my ride. I just installed the rears because 1 of the tires that came with them is completely shot, and I'm thinking about getting wider tires on 2 of the wheels anyway to go on the rear. They are 205/40R17 Fuzion ZRi tires. I'm thinking 225/40R17 for the rear and moving the 205's up front. I also have to check the clearance on everything and didn't have time to do it. The wheels came with a pair of 20mm spacers and extended lug studs with nuts. They don't look bad on my car at all.
Post by Ryki » Mon May 13, 2013 12:48 am
I gotta say that I love new old rims, cheap way to change the look and feel of things! I hope size and fit, fit you well I hope they fit and treat you well!
Post by M20_fever » Mon May 13, 2013 1:39 am
Needs WAY higher aspect ratio, or you need to slam that thing on the ground. Wheel looks freaking tiny, not really feeling it with those tires.
Post by 87e30 » Mon May 13, 2013 5:03 am
The tires ARE smaller than I want, but it really looks a lot better in person than in the picture. In person it doesn't look bad at all. I think the angle I took the shot from, and the huge meaty rubbery front tires make the rears look that much smaller. Try covering the front part of my car in the pic and look at the back wheel. Makes a big difference IMO.
Who makes a good CHEAP tire in 205/45R17 or 225/40R17? I'm actually not as impressed with the Fuzions as I thought I would be from the reviews. Most people were saying how they could hit like 360 degree turns at 480MPH and grip the whole way (obviously exaggerated), but I thought I was feeling some slip in them at 40MPH on turns that were nothing special. May have been at least partially due to them being VERY low on air though. I should have checked the air before driving on them.
Post by M20_fever » Mon May 13, 2013 5:35 am
Craigslist man, I don't think I'll ever buy new tires for a DD again.
Post by 87e30 » Mon May 13, 2013 12:23 pm
Where do you think I found the wheels? lol
Post by Nsquared97 » Mon May 13, 2013 4:26 pm
I don't know about cheap, but there are tons of great 225/45/17's out there, and they will grip like glue. Fuzions aren't exactly all that great... 205/40 is just tiny. Also, keep in mind if you put wider tires on the rear it won't want to oversteer as much.
Post by 87e30 » Mon May 13, 2013 6:33 pm
225/45R17's are .99 inch taller and over an inch wider than stock. Will those rub? I do plan on lowering my car too.
