Dan's 2nd E30 Build
Re: Dan's 2nd E30 Build
Postby M20_fever » Sun May 01, 2011 4:46 am
can't wait to see the new direction!
Postby ponycarman » Sun May 01, 2011 5:44 pm
^^ Likewise!
straight6pwr
Postby straight6pwr » Mon May 02, 2011 1:56 pm
going to go with euro lights, as the low beam lens is perfectly clear where the cut-off shines through (best output/sharpest cutoff). most likely will pick up brand new Depo lights because it will guaranty no-pitting and also then I dont have to hack-up a perfectly good genuine set.
Postby M20_fever » Mon May 02, 2011 2:02 pm
Nice! Are you going with regular elips or smilies?
straight6pwr
Postby straight6pwr » Mon May 02, 2011 4:47 pm
i'd love to go with non-smileys, but the depo's only come in smiley. if i can find a used set for a good deal, i would jump on that instead.
straight6pwr
Postby straight6pwr » Sat May 21, 2011 9:59 pm
smoked euro smileys have been ordered!
also, today i tackled my other wheel bearing, which started making noise last week. it started to pour on me half way throw so i had to rig up some cover! also took a couple of artsy shots of the wheels in the rain.
Postby ponycarman » Sat May 21, 2011 11:14 pm
Cool pics! Front wheel bearings aren't to bad to change. Should do a write up if you got pics of the process. Awesome work!
straight6pwr
Postby straight6pwr » Sun May 22, 2011 2:55 pm
as you can see from the first few pics, that was the direction i was going in. the rain put a stop to it as i didnt want to ruin the camera.
Postby Yoshi » Sun May 22, 2011 3:01 pm
I hate the locking nut for the rotor. I never put them back on. There really is no point in them. The front wheel bearings really aren't that bad. I didn't need to use any special tools when I did them. The bearings themselves are expensive as hell though.
straight6pwr
Postby straight6pwr » Sun May 22, 2011 4:16 pm
Yoshi wrote:I hate the locking nut for the rotor. I never put them back on. There really is no point in them. The front wheel bearings really aren't that bad. I didn't need to use any special tools when I did them. The bearings themselves are expensive as hell though.
yeah easy job. the rotor bolt should be used as follows: 1) use rotor bolt to hold rotor on 2)install brake caliper 3) remove rotor bolt since now the caliper is doing its job
Postby M20_fever » Mon May 23, 2011 11:43 pm
straight6pwr wrote:yeah easy job. the rotor bolt should be used as follows: 1) use rotor bolt to hold rotor on 2)install brake caliper 3) remove rotor bolt since now the caliper is doing its job
so true.
straight6pwr
Postby straight6pwr » Tue May 24, 2011 3:27 am
did the first step towards tackling my ripped sway bar tab. removed the existing stock mount and the bar so that I can take in the car and get the tab welded and the reinforcements welded in as well:
drivers side tabbed ripped, with the bracket and bushing no where to be found. it caused the bar to shift and links to bind on the passenger spring making an annoying popping sound when compressed.
remove one side wheel, spring, strut to easily pull the bar out.
what was left of the stock mounts: (bushing toast anyways)
bar out: crusty!
parts to be installed after the tab is welded:
Postby M20_fever » Tue May 24, 2011 11:20 am
yikes, that thing has seen better days.
Postby Yoshi » Tue May 24, 2011 3:35 pm
lol people strengthen their rear sway bars, I got rid of mine.
Postby M20_fever » Tue May 24, 2011 4:59 pm
Depending on how my race on Monday goes I may be removing mine as well. For street driving I would still run a rear sway though.
Users browsing this forum: Bing [Bot] and 5 guests
