A tale of 2 E30's.
Re: A tale of 2 E30's.
Postby Nsquared97 » Wed Apr 03, 2013 4:53 pm
I'm not seeing any labels, but that recessed part helps, thanks.
Postby Nsquared97 » Thu Apr 04, 2013 5:26 pm
Oooo, what did the UPS guy bring me today...?
-yuush-
Postby Yoshi » Thu Apr 04, 2013 5:32 pm
I'm gonna stick with sex doll.
Postby Nsquared97 » Thu Apr 04, 2013 6:01 pm
All your topless posts on FB have been exactly what it was modeled after.
Postby Yoshi » Thu Apr 04, 2013 6:48 pm
it's a hard standard for others to live up to. I know.
Postby AustinR » Fri Apr 05, 2013 12:49 am
Get a room you two. Then, Nick, you could have the real thing!
Postby Nsquared97 » Fri Apr 05, 2013 5:07 am
So here's what was in the box...
Ireland Engineering 25mm adjustable front swaybar kit. Adjustable spherical bearing endlinks, and poly bushings.
And an Ireland Engineering poly steering coupler. I'm excited :D
Postby Nsquared97 » Fri Apr 05, 2013 8:14 am
So it's 4am, and for the second time in a month I just got back from the mandatory test drive after installing new parts. Car feels significantly better, I think I need to tweak the endlink lengths, kinda just did a quick and dirty job so I could take it for a drive. Anybody have any good methods for getting them set just right?
Postby Yoshi » Fri Apr 05, 2013 11:55 am
The sway bar should be parallel to the ground when the car is on a flat surface and all 4 wheels settled on the ground. IE you should adjust them WITHOUT jacking up the car.
Postby ten2doyle102 » Fri Apr 05, 2013 12:09 pm
Did those have issues fitting at all? Just curious cause a friend of mine had a heck of a time getting his front bar in. I don't remember why though.
Postby Yoshi » Fri Apr 05, 2013 12:18 pm
The front bar is usually a pita because of the slip in brackets. There needs to be tension on the bushings so they are slightly oversized but in doing so, it always "unslips" a bit. Stupid stupid design.
Postby M20_fever » Fri Apr 05, 2013 12:59 pm
wish my class allowed adjustable sways. What size sway is that?
Postby ten2doyle102 » Fri Apr 05, 2013 4:32 pm
Tony, do you have bigger sways at all? It would just bump you into the next level correct?
Postby M20_fever » Fri Apr 05, 2013 6:18 pm
I'm running stock sways. I could run bigger, but they cost points and I'm maxed out for this class.
Postby AustinR » Fri Apr 05, 2013 10:38 pm
M20_fever wrote:What size sway is that?
Nsquared97 wrote:...Ireland Engineering 25mm adjustable front swaybar kit...
Users browsing this forum: Bing [Bot] and 3 guests
