Yoshi's Modded knuckle kit R&D
e30 gangsta
Re: Yoshi's Modded knuckle kit R&D
Post by e30 gangsta » Mon Feb 20, 2012 5:40 pm
On the wise fab kit you can't run a sway bar.
Post by Yoshi » Mon Feb 20, 2012 7:56 pm
it'd have to be M3 style
e30orDie
Post by e30orDie » Wed Apr 18, 2012 3:42 pm
blehhhh lil teaser update... There's no hub on the test struts.... so wheel was just held up accordingly.
ALSO.... im not looking for "MORE" angle.... im really after ackerman correction, like what a dirt track or sport atv quad has at full lock. You will be able to see more angle at turn in (trailering tire) and that is what I have been after.
I did order my metal today though.
Currently sitting on the stock e46 joints, as I am still waiting on the others.
On a side note, that will disappoint yoshi.... I have eliminated tapers..... Everything will be 5/8'' high grade bolts. NO TAPERS
Reasoning being.... cost.... The cost of machining OUR**** tapers is gonna be rediculous... Ive been digging through taper cutter (for the machine shop) and.... haven't found any.... and Im kinda glad, at about 350$ a cutter................... which what happens when one breaks, or wears out? the cost of a kit would go up significantly due to these cutters-
but as of right now, I should be able to make these kits extremely DIY easy and cheap. IF I end up selling these, It'll be just the block, the strut mounts, and the press in bearing sleeve for the e46 arms. I will then provide everyone will the part numbers to the high misalignment bearings, and tie rods...... SO, that IF you NEED to replace one.... you can do it on your own, without having to wait or get a hold of me. To me this is the beauty behind it.... all joints will be able to be replaced BY YOU, ordering them on YOUR OWN. (I of course, can send you them as well.... but there is no need)
I'll have about 500$ in this kit by the time I test it. However, once everything test out fine this summer, I will be able to cut that price down by about 200$ I hope :D
Post by Yoshi » Wed Apr 18, 2012 6:02 pm
looks promising. boo with all the custom parts though lol.
keep it up!
Post by Nsquared97 » Thu Apr 19, 2012 1:18 am
Really cool to see poepl putting this kind of effort into developing stuff for E30's, keep up the good work!
metris228
Post by metris228 » Tue Nov 20, 2012 4:47 am
e30orDie wrote:
e36 outer (current)
Part Number: NCP 2693048
Product Line: NAPA Chassis Parts
Attributes:
Large Diameter Taper (Dimension B) : .55"
Length (Dimension F) : 8.5"
Right or Left Hand Threads : RH
Rod End Thread (Dimension A) : M14 - 1.5
Small Diameter Taper (Dimension C) : .5"
Taper Length (Dimension D) : .5"
Thread Type : Female
e9x inner (current)
Part Number: NCP 2693614
Attributes:
Overall Length (Dimension D) : 10.97"
Rack End Thread (Dimension A) : M18 - 1.5
Rod End Thread (Dimension E) : M14 - 1.5
Socket Flat O.D. (Dimension B) : 1.48"
Type : 2
Hey mate, do you know what the taper details are for the control arms inner and outer ball joints?
Or do you know where I can find them?
Post by Yoshi » Mon Mar 18, 2013 12:11 pm
bueler....
Post by M20_fever » Mon Mar 18, 2013 12:41 pm
Why bump?
Post by Yoshi » Mon Mar 18, 2013 12:57 pm
I might actually know someone around here that can make this for me. Or I wanted to see how E30orDie was doing with his.
Ciclajbek
Post by Ciclajbek » Wed May 15, 2013 4:36 pm
does someone know how much excatly wisefab control arm is longer than stock one?
friend of mine and I are playing with waterjet these days and here is what we made, but dunno how much wheel goes out
Post by Yoshi » Wed May 15, 2013 4:58 pm
it's supposed to be like an inch longer on each control arm than the E46 one. I think the E46 one is 1 inch longer than stock. So... 2 inches? IE 50mm
Ciclajbek
Post by Ciclajbek » Thu May 16, 2013 6:55 am
their site says ~100mm per side, but I need exactly measure... e46 are cca 35mm longer....SLR kit is 57mm longer, and wisefab is longer than SLR
new adapters on 3 holes for e36
Post by Yoshi » Thu May 16, 2013 11:09 am
I don't think any of us have the wisefab kit so we can't say for sure. Will those adapters work on E30s???
Ciclajbek
Post by Ciclajbek » Thu May 16, 2013 3:14 pm
e30 must have adapters on 4 holes, we have made them too, but we didn't made a "teeth" on surface because e30 knuckle has diferent heights of screws for CA and tie rod
Post by Yoshi » Thu May 16, 2013 3:35 pm
sell me a set?
