E30 325e to 325i Turbo
MaikelK
Re: E30 325e to 325i Turbo
Post by MaikelK » Thu May 02, 2013 2:30 pm
It's now near to completion, so thats why it's on a pallet haha.
During built it was at normal working height in my engine support.
Manifold it TIG welded, but big welds haha. I was there when he was welding it ;)
Post by Yoshi » Thu May 02, 2013 4:35 pm
gotcha. carry on.
Post by M20_fever » Thu May 02, 2013 9:49 pm
looking good!
MaikelK
Post by MaikelK » Fri May 03, 2013 8:07 am
Will do, and thanks!
MaikelK
Post by MaikelK » Sun May 12, 2013 7:14 pm
So, the oil lines have been tigwelded and then pressuretested at 5 bar. No more leaks.
Few weeks ago i bought a 2,79LSD with 188 housing.
Top speed with 205-50-16 tires at 6000 rpm would be something like 305km/h (190mp/h) -omg-
So this weekend i fitted the oil lines, bought some cheap oil because i know myself, and fitted an oil pressure gauge on the engine.
So i started, and yes, oil leak, completley forgot the oilcooler lines. :shock:
So fixed it, and started, after a few seconds oilpressure started to build and Tunerstudio was showing 230 rpm.
Oil pressure was 3.8 bar.
Tested the injectors with some pressure but not 3 bar and flow haha. I dont have a good fuelpump yet to test.
But he, it works.
Now with fuelpressure on the rail, during start the injectors where firing.
Im only waiting for a plug for my Opel Omega V6 wastedpark coilpack.
Oliepressure test
https://plus.google.com/photos/10620422 ... 3914285602
Injector test
https://plus.google.com/photos/10620422 ... 0562884658
Post by M20_fever » Sun May 12, 2013 8:47 pm
Very nice. I hope those injectors atomize a bit better at full pressure. I assume your top speed calcs don't take drag coefficient into account, because I don't think any M20 will ever make enough power to push an e30 to 190+mph, and if it did, I wouldn't want to be IN an e30 going 190mph, lol.
Post by Yoshi » Sun May 12, 2013 10:07 pm
Wow someone that actually uses google plus lol. Wow you did a lot more testing than I normally see. Very good work man! I'm impressed.
Post by Ryki » Mon May 13, 2013 12:34 am
Such a clean and meticulous build, so sexy!
MaikelK
Post by MaikelK » Wed May 15, 2013 10:29 am
No, it doesn't take drag into account haha.
It's on Google plus because I used Picasa for uploading haha.
And I hope testing it before installing keeps me away from flooding engine and leakages and so on.
This fuelpump has no pressure what so ever, maybe half a bar.
MaikelK
Post by MaikelK » Wed May 15, 2013 7:17 pm
Mmm.
So i wired up my Vauxhall/Opel/GM/Saab coilpack.
Tested the outputs and all is firing.
But when i crank the engine, only output A is firing, i can see this by the leds on the ECU!
Is this normal? Or is something wrong?
Do you guys have any idea?
EDIT: How can i forget a movie about it, haha
https://plus.google.com/photos/10620422 ... 2193996914
Post by M20_fever » Thu May 16, 2013 12:25 am
That link just points to your gallery. I forget, what EMS are you running?
MaikelK
Post by MaikelK » Thu May 16, 2013 5:21 am
Im running megasquirt clone KDFI.
But I think it has something to do with my settings or what so ever!
Post by Yoshi » Thu May 16, 2013 11:11 am
I've never heard of KDFI so I can't help you a huge amount. With an MS1 or 2, you have to wire in 2 more coil drivers to get 6 cylinder wasted spark.
And no, that's not normal
MaikelK
Post by MaikelK » Thu May 16, 2013 1:13 pm
Yeah, i know that with the drivers, and in output test mode, all coils are firing!
Post by Yoshi » Thu May 16, 2013 1:25 pm
then I guess you're ok?
