Just picked up this beaut.... lol! 1984 Grey Market 323i
Re: Just picked up this beaut.... lol! 1984 Grey Market 323
Postby M20_fever » Tue Dec 10, 2013 3:28 pm
yeah, had to bitch slap my old eta to get the temp gauge to work, lol.
Postby ten2doyle102 » Tue Dec 10, 2013 3:56 pm
Tony,
There's a 1990 318i for sale locally that was in a little fender on the passenger side. I was thinking about grabbing it for a parts car, does your dad need anything for his off it? Its diamond schwartz
Postby M20_fever » Wed Dec 11, 2013 5:18 am
Texted you about this, but yeah based on the pics the rear bumper and pass door look like I could use them. Are you using the grills? Throw up some better pics when you get it and I'll see what else I can use.
Postby ten2doyle102 » Wed Dec 11, 2013 3:06 pm
Ok, I don't know IF I am going to get it. I honestly don't need another car sitting on my property... Figure the City might get pissed. lol
Dude wants $800 for it, but he's got some snow tires too. If he throws them in, it would probably be worth it.
Postby M20_fever » Wed Dec 11, 2013 3:14 pm
right on, just let me know if your getting it.
Postby ten2doyle102 » Thu Dec 12, 2013 2:49 am
ok, so I braved the insane cold tonight to do a little digging on the power draining issue.
I did the old hook up a multi-meter in series thing with the battery to read the amp draw with the car off. At rest, the meter was picking up around 4 amps assuming I was using the meter right.... (I am not to savvy with those things.....) Anyway, I started pulling fuses and found that when pulling fuse 21 the draw disappeared. Well, that leaves many circuits that could be the culprit.
- Auto-charging flashlight
- Ignition key warning/seatbelt warning
- Interior lights
- Radio/antenna
- Trunk light
- Multifunction clock
- Service interval indicator
Of that list, these are the things that do not work now., interior lights, trunk lights and I think the tach/mpg gauge is tied into that as well, which doesn't work either. So I am assuming that it is probably related to one of those things. another thing to notice, the amp draw changes when I open the drivers side door, but not with the passenger side... any idea about that???
Also checked the alternator, it was outputting 13.6V while running so I assume that's ok.
What actually causes the draw? Can a bad ground or something do it? I am not very good with the electrical side of things so any assistance would be great!!!
Thanks!
Matt
Postby M20_fever » Thu Dec 12, 2013 4:59 am
The switch for the drivers side door chime is what's drawing the extra amps when you open the door. You know what circuit is bad, so time to dig deeper and test each component on the circuit one at a time. I would start with the radio since a bad installation (aftermarket?) can cause constant draw. If that checks out I would look at the interior/trunk lights for bad grounds or frayed wires.
Postby ten2doyle102 » Thu Dec 12, 2013 11:06 am
Stock radio I believe for the car. Can I simply unplug the interior lights/door switches to find the bad circuit?
Postby M20_fever » Thu Dec 12, 2013 4:02 pm
You can start with that, but if the problem is in the harness it may still be grounding out somewhere.
Postby ten2doyle102 » Thu Dec 12, 2013 4:11 pm
Ah, so a frayed wire could be the cause? Sorry, I don't know much about electrical systems.... lol
Postby ten2doyle102 » Thu Dec 12, 2013 4:12 pm
Also, if I open the door though, the draw goes away.... they don't increase.
Postby M20_fever » Thu Dec 12, 2013 8:11 pm
wait, the draw goes away when you open the door? So it drops to zero with the door open?
Postby ten2doyle102 » Fri Dec 13, 2013 11:00 am
Well, it actually changes...but I guess I can't tell if its going up or down because the meter goes from 4.07a to 1. Just a one.
Postby M20_fever » Fri Dec 13, 2013 2:20 pm
what setting are you using on the DMM?
Postby Court M3 » Mon Dec 16, 2013 10:16 am
Fix rust, 5sp swap, few simple cosmetics and keep it stock. Next e30 I purchase will be left mostly stock with only OEM mods. Nice find!
