87 vert, m50 swapped
Blaine0002
Postby Blaine0002 » Tue Sep 30, 2014 2:34 am
Hi ill be posting my progress and probably be asking some questions as i rewire and tune a megasquirt
Started here
Now here
Re: 87 vert, m50 swapped
Postby Yoshi » Tue Sep 30, 2014 10:30 am
Damn clean car. Why megasquirt?
Postby M20_fever » Tue Sep 30, 2014 2:16 pm
Quite a transformation so far, very nice! Welcome aboard!
Blaine0002
Postby Blaine0002 » Tue Sep 30, 2014 5:57 pm
the m50 i got fully rebuilt, new pistons, rings, rods, redecked, honed, arp bolts all over the place and a thick metal headgasket.
Will be looking into sourcing turbo parts soon, but I figured id get it running off megasquirt before that happens
Postby Yoshi » Tue Sep 30, 2014 7:42 pm
Ah not a bad idea. Although, honestly, I'd go with just a chip. I did the MS route and wound up getting an rk tune chip. Made things much simpler and kept costs down.
Postby blasphemy101 » Fri Oct 17, 2014 1:26 pm
Yeah there are a handful of well-known setups based on chipped ECUs that put down more power and better powerbands than you'll ever need. For M5x/S5x, the only advantage of MS is its flexibility. If you're planning on making lots of changes over time or have a setup in mind that isn't supported by any of the chips on the market, then Megasquirt is a better idea.
