Yoshi's E46 wagon saga
Re: Yoshi's E46 wagon saga
Post by 87e30 » Thu Mar 17, 2016 1:59 am
Nobody makes a real station wagon anymore. Gimme a 3 door e30 touring and I'll be about as happy as a man can be. But I'd take just about any early 90's or older wagon and be happy as well. Maybe a couple later 90's, but definitely nothing past 99, and preferably nothing with any airbags whatsoever (unless we're talking suspension lol).
Ahh, sporty trucks... Reminds me of when I almost bought a Typhoon. From the factory that thing was sick!
'inherently not "bmw"'... Have you seen what they've done with the company lately? I've heard rumor of a front wheel drive V6 soccer mom mini van. I really hope it isn't true. I'm honestly afraid to look it up.
Post by Yoshi » Thu Mar 17, 2016 11:55 am
Yea. I'm getting more and more unhappy with them post E46. BUT I talked to a few guys at a bmw race shop. They hate all E90s but love the F30s. So I have some hope.
Post by 87e30 » Thu Mar 17, 2016 4:22 pm
Post by M20_fever » Thu Mar 17, 2016 4:41 pm
I hate that none of the e30 truck builds have opening tailgates...pretty much makes a truck pointless. Personally, I want to make an e38 pickup.
Post by Yoshi » Thu Mar 17, 2016 4:43 pm
sexy wagon? looks like a giant hunk of lead lol. I'm not too keen on the old american looks.
Post by 87e30 » Thu Mar 17, 2016 10:33 pm
Yoshi wrote:sexy wagon? looks like a giant hunk of lead lol. I'm not too keen on the old american looks.
That's RACIST! -yuush- lol
Yeah, I would love to see one with an opening tailgate also. Not opening doesn't make them pointless, but definitely less functional.
Post by Yoshi » Fri Mar 18, 2016 12:27 pm
I should work on the wagon. Gonna get some fresh gas in it soon and drive it around. See if I can get the ABS lights to go out just on distance.
I think maybe the DME has to go through checks or something. *shrugs*
Post by Yoshi » Mon Mar 21, 2016 10:52 pm
Well I got PASoft installed after a fight with drivers in windows 10 (gotta manually find the driver from the list instead of just browse for it). Also took me a while to realize that early E46s 100% DO have the 20 whatever pin connector under the hood and the OBD2 interface won't work.
Anywho, this is what it gave me:
And here is the hilarious print out. I'm actually amused or in disbelief that the DMEs were both within 1km of each other. The simple fix at this point looks like just swapping out the LCM and cluster with the donor car and most things will go away. Also looks like the rear driver's wheel speed sensor is on the fritz. Sadly, I've never successfully pulled one of those out.
BMW Scanner v1.4.0.9 (19.09.2011) - P.A.Soft, 2011 HW: V144Bn9 Time: 4:45:52 PM 3/20/2016
ZCS coding : /-------- IKE --------\ /-------- EWS --------\
Chassis : E46 E46
Model : 323i 328i
Type key : AR33 AM53
Engine : M52B25 M52B28
Gearbox : Automatic Automatic
VIN : JM01284 WBAAM5342YKG17873
ZCS GM : 69330000-4 66530000-7
ZCS SA : 00000A0007A8D408-0 00002A0807AC1400-A
ZCS VN : 0000600620-X 00004896FB-4
Chassis : E46 E46
Model : 323i 328i
Unit BMWTNR HW SW-FSW CI DI BI/VI Date Odometer VIN ADFG Algorithm
EWS -> 6.905.670 03 08 81 81 07 34/99 250855 km WBAAM5342YKG17873 FFFFFF EWS3
DME -> 7.500.255 15 E3 00 C0 60 36/99 - WBAAM5342YKG17873 FFFFFF MS42.0 M52 (EWS3)
ABS -> 6.753.598 02 36 09 70 60 23/20 - - 001284 DSC E46
LEW -> 1.094.142 06 02 01 01 60 08/00 - JM01284 001284 LWS5
IKE -> 6.902.371 09 16 04 52 10 14/00 250854 km JM01284 020000 93S66 - E46 (E46)
LCM -> 6.901.431 08 13 28 20 00 12/00 250800 km JM01284 000000 HC11P2 - 4 (LSZ)
SHD -> 3.861.939 05 31 01 02 78 11/00 - - 111284 SHD E46/R40
# SCAN START
A/C -> 6.902.440 21 05 03 32 0A 15/00 - - 001284 IHKA E46 PU98/PU99
SRS -> 6.905.491 01 05 31 08 00 13/00 - JM01284 000000 MRS3 E46
ZKE -> 8.385.544 11 12 01 40 08 14/00 - - 401284 ZKE5
MFL -> 0.000.000 01 07 00 03 78 00/00 - - - MFL2
RAD -> 6.909.882 32 11 01 11 08 15/00 - - 001284 Radio ZIS/BM/MIR
SZM -> 8.379.751 01 01 20 20 78 02/00 - - - SZM E46
SPMFT -> 8.386.427 02 01 01 01 01 13/00 - - 001284 SPM E46 Driver
SPMBT -> 8.386.427 02 01 01 01 01 13/00 - - 001284 SPM E46 Passenger
SMF -> 8.263.133 07 0B 01 01 01 01/00 - - 001284 SM 3-channel E46/E85
EKP -> - - - - - - - - - - -
# USER INFO FIELDS
Unit Date VIN Odometer Assembly Software Service Dealer Tester Program ver.
DME -> 21.09.99 WBAAM5342YKG17873 0 km 7.505.515 7.505.516 7.505.552 000017 00000 -
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY
DME -> 7.500.255 15 E3 1 error / 2 errors
EWS -> 6.905.670 03 08 8 errors
ABS -> 6.753.598 02 36 3 errors
LEW -> 1.094.142 06 02 2 errors
A/C -> 6.902.440 21 05 no errors
SRS -> 6.905.491 01 05 1 error
IKE -> 6.902.371 09 16 5 errors
LCM -> 6.901.431 08 13 no errors / 7 errors
ZKE -> 8.385.544 11 12 3 errors / 8 errors
MFL -> 0.000.000 01 07 no data
RAD -> 6.909.882 32 11 no errors
SZM -> 8.379.751 01 01 no errors / 2 errors
SHD -> 3.861.939 05 31 no errors
SPMFT -> 8.386.427 02 01 2 errors / 3 errors
SPMBT -> 8.386.427 02 01 2 errors / 4 errors
SMF -> 8.263.133 07 0B no errors
EKP -> <found> unknown
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME -> 7D/A1 - Activation, electric fan
Shadow-memory:
7F/02 - Activation, solenoid valve, suction-jet pump
EWS -> 33/3F - Toleration of changing code increased, key 3
13/01 - Toleration of changing code increased, key 1
0F/3F - Power on reset
43/3F - Toleration of changing code increased, key 4
42/02 - Wrong changing code, key 4
41/04 - Wrong password, key 4
40/03 - Wrong identification, key 4
0E/01 - DME changing code XOR-error
ABS -> 78/01 - Vehicle power > 18 Volt
96/FF - CAN timeout EGS
31/FF - Wheel speed sensor rear left trigger signal
LEW -> 09/67 - No CAN message (ASC)
01/05 - Terminal 30 defective
SRS -> 11/A0 - Power supply
IKE -> 11/84 - Thermal oil-level sensor
D7/81 - Tank sensor 2
FB/C4 - No CAN message (EGS1)
87/82 - Body bus (K-bus)
BF/88 - Internal fault, EEPROM checksum, coding incorrect/incomplete
LCM -> Shadow-memory:
34/01 - Brake light, left
36/22 - Turn indicator, front left
37/22 - Turn indicator, front right
39/24 - High beam, left
3A/22 - High beam, right
41/3F - Low beam, right
42/1D - Low beam, left
ZKE -> 30/01 - K-bus or Control unit for Instrument cluster basis (Gateway)
33/01 - Wiper: is blocking or Reset contact
45/01 - Central locking system: Lock contact Driver's door
Shadow-memory:
81/3F - Alarm memory: Door contact Driver's door
8A/3F - Alarm memory: Radio interior protection
8F/01 - Alarm memory: Panic modus was activated
88/04 - Alarm memory: Hood
84/01 - Alarm memory: Door contact Passenger side behind
90/3F - Battery Voltage: Open circuit
89/24 - Alarm memory: Tilt alarm sensor
8D/01 - Alarm memory: Lock contact Driver's door
SZM -> Shadow-memory:
05/1D - Seat heating Lower voltage recognised
06/1E - Sun rollo Lower voltage recognised
SPMFT -> 04/01 - Mirror-moving-switch, interruption
09/01 - Mirror drive vertical interruption
Shadow-memory:
00/54 - Low voltage ( U < 8,5 Volt )
01/C4 - High voltage ( U > 16 Volt )
02/9A - Low voltage mirror-heating
SPMBT -> 07/3F - Mirror drive, potentiometer vertical
08/3F - Mirror drive, potentiometer horizontal
Shadow-memory:
00/50 - Low voltage ( U < 8,5 Volt )
01/82 - High voltage ( U > 16 Volt )
02/B5 - Low voltage mirror-heating
04/0D - Mirror drive, potentiometer plausibility
# SCAN END
Post by M20_fever » Fri Mar 25, 2016 8:53 pm
lol, why does it say its from a Limo?
Post by Yoshi » Sat Mar 26, 2016 1:42 pm
Yea... I don't know? Maybe it's a german term for something. But holy crap this damn thing can do so much. I wish my E30 had it. Sad part is that I can't get the ABS module to forget that it's automatic. I'm going to try to swap out the innards without breaking any fluid. With that, ALL the lights will go out AND the odometer will read the correct mileage for the car even though it's the manual cluster!
Post by Yoshi » Sat Mar 26, 2016 8:45 pm
Well if anyone wants to know, the DSC comes off with 4 E6 bolts and keeps the brake system sealed. The down side is that I now have this code:
ABS -> A3/FF - Lateral acceleration sensor electrical failure
But I've decided, I really don't care about DSC. I'd really like to kill this suction-jet pump code.
Anywho, I put in the new radiator today and bled the cooling system. All seems well minus a MAF code that was likely tossed from me starting the car with the res cap off and coolant going everywhere (and into the MAF since I have no filter on it right now). I ordered depo head lights from amazon since my old ones are bunk. I just need windows front and rear and this baby can hit the road! Or at least enough to find out what fails for safety.
Post by M20_fever » Tue Mar 29, 2016 7:43 pm
Nice! Did you find a better price on the rear window?
Post by Yoshi » Wed Mar 30, 2016 11:31 am
So uh... there aren't any new windows in the US. Like... at all. Even used units. The guy that I called found one in fucking canada. On the bright side, it'll cost me 1/3 what a new window will.
Post by M20_fever » Thu Mar 31, 2016 2:32 pm
Jeeze, I didn't think those were that rare. You should call Knautz BMW in Lake Forest, IL for hard to find stuff. Their a massive dealer that stocks a lot of "old" BMW parts. I've gotten several e30 parts they had in stock as long as I could provide the part number.
Post by Yoshi » Fri Apr 01, 2016 11:44 am
"Old". I guess the car is 16 years old. only 2 generations removed :(
