Quick E30 reshell
Quick E30 reshell
Postby Yoshi » Mon Jul 10, 2017 10:39 pm
The S52 E30 went into a wall. front coil may have failed or the axle may have locked up. Regardless I'll make a video series!
Re: Quick E30 reshell
Postby M20_fever » Tue Jul 11, 2017 12:53 pm
What's the plan? Swap everything to a new shell?
Postby Yoshi » Tue Jul 11, 2017 4:19 pm
Yep. The hope is to get the quickest route back on track. Pull everything worth a damn, put into new car. Rock on.
Postby Yoshi » Thu Jul 13, 2017 12:45 am
Postby M20_fever » Tue Jul 18, 2017 2:28 pm
can't see pic...host it here.
Postby Yoshi » Tue Jul 18, 2017 2:56 pm
Postby Yoshi » Tue Jul 18, 2017 9:52 pm
Pulling the interior - https://youtu.be/8QxIGWdiZDI
Postby M20_fever » Wed Jul 19, 2017 5:02 pm
weird, post as blank so I assumed it was a blocked pic.
Postby Yoshi » Mon Jul 24, 2017 11:39 pm
Postby M20_fever » Wed Jul 26, 2017 1:20 pm
Video isn't showing up, are you using the youtube tag?
Postby Yoshi » Wed Jul 26, 2017 11:24 pm
yea. works fine on every computer I use...
Postby M20_fever » Thu Jul 27, 2017 2:21 pm
I'm sure it's my work blocking it...
Postby Yoshi » Fri Jul 28, 2017 12:03 am
Well I mean... you should be working anyways. https://www.instagram.com/p/BIXVGT9jqkb/ if you want a direct link.
Postby Yoshi » Sun Jul 30, 2017 12:24 am
Postby Yoshi » Mon Jul 31, 2017 1:04 am
Return to “Builds”
