e21?
WildKarrde
Re: e21?
Postby WildKarrde » Wed Jul 24, 2013 1:02 pm
Driven one? Yes, quite a few years ago. I was looking for an E30 but found an E21. It was a 320i, I think. Fun car, great brakes, I wanted to buy it, but not for $5000, so I've never owned one.
(OO==[][]==OO)
1990 BMW 735i
1987 BMW 325e
1988 BMW 325i Convertible
Check out my Project C.A.R.S. videos!
https://www.youtube.com/c/WildKarrdeGaming
e21jps
Re: e21?
Postby e21jps » Sun Sep 08, 2013 2:00 am
he everyone first post, as you might guess i love e21's. i race one with m20 and lots of performance goodness etc.
this hasnt been updated for a looong time but heres site i made years ago with all my progress building it up
http://e21jps.webs.com/
we just build new engine 2.9 with 293rwHp
Re: e21?
Postby Yoshi » Sun Sep 08, 2013 11:37 am
While you're here, can you explain the main suspension differences between E21s and E30s? IIRC the rear suspension is only minorly different but the fronts are something very different.
Re: e21?
Postby M20_fever » Mon Sep 09, 2013 3:25 am
Details on the new 2.9 you built? Thats pretty impressive HP for an NA m20.
Re: e21?
Postby Ryki » Mon Sep 09, 2013 11:00 am
I second that!
e21jps
Re: e21?
Postby e21jps » Fri Oct 04, 2013 12:17 pm
The main difference with the front suspension is the bottom arms, the e21 is more conventional style with single arm, the sway bar is fixed to the front chassis rails and also acts as the radius rod to keep the front arm in position very simple, it has lots of big rubber bushings which need changing for lurethene if you want to improve the handling. The rear is much the same as e30 but it has a full coil over shock instead of the spring sitting on the arm
my new engine has our own itb intake and roller cam, head is a 731 casting with 44 and 36 valves lots of port work, crank is a usdm m3 with 86mm stroke, aftermarket H rods and 85mm flat top CP pistons, headers and exhaust are custom stainless
Re: e21?
Postby M20_fever » Fri Oct 04, 2013 3:35 pm
Im assuming your power is made inbthe head work? Nothing else in that setup seems out of the ordinary for an m20 stroker. Whats this about a custom cam? specs?
Return to “General Tech”
