Easiest way to get broken subframe bushings out
Postby Yoshi » Fri Jun 22, 2012 1:30 pm
5/8" threaded bolt. Tap or thread it into the broken bit, hammer out from the top.
Re: Easiest way to get broken subframe bushings out
Postby ten2doyle102 » Fri Jun 22, 2012 3:19 pm
You don't happen to have a pick of this things location on the inside of the car do you? I am assuming to hammer the part do you'd have to do it from inside, right?
Postby Yoshi » Fri Jun 22, 2012 3:55 pm
I can get pics. I haven't put the new subframe bushings and such in yet. Basically, there's a stud inside the chassis that protrudes down and the bushing/nut goes on that. If you pop up the back seat and pull out the rubber-ish foam, you can tap the stud out from the bottom. Thread this bolt in the bottom and hammer down from the top with the stud or a screw driver.
Postby M20_fever » Fri Jun 22, 2012 7:43 pm
Pics please!
Postby Yoshi » Fri Jun 22, 2012 9:25 pm
someone text me after noon tomorrow so I remember.
7pilot
Postby 7pilot » Thu Jun 28, 2012 3:22 pm
This is the Right side rear corner under the seat.
There is a hole on the outside of the tube brace at the outer rear corners of the seat bottom.
This is the hole. You can see the head of the stud. To remove, you have to pound it up from under the car.
This is an M3 . I believe the 3xxs are the same.
m
Postby Yoshi » Thu Jun 28, 2012 4:26 pm
They are. Thanks for posting that. I totally forgot!
