Motor been in for a bit. What would you retorque/check?
Postby Yoshi » Mon Jun 10, 2013 11:27 am
Basically, I'm paranoid as fuck. Too many bolts/fluids/issues to think about to get it done right in the first go. I've driven the car around for a good 20 miles and feel like it's a good time to get under it and make sure all the bolts are still there and nothing is uber leaking.
Things I'm gonna retorque/check:
Motor/trans mounts
drive shaft bolts
clutch fan (yep, managed to keep mine)
intake mani
What else? I figure things like the exhaust would have leaked by now. I also figure internal components or things like the oil pan would also have leaked but also might be more prone to leak if I get back at them. Hence why I'm leaving the head bolts be. They are ARPs anyway so I'd have to take the cams out. Maybe I should retorque the cam bolts... At one point in time, this motor was 100% apart minus bottom end rotating assembly.
Re: Motor been in for a bit. What would you retorque/check?
Postby M20_fever » Mon Jun 10, 2013 3:19 pm
meh, I'd let it ride, lol.
Postby Yoshi » Mon Jun 10, 2013 3:25 pm
In my past experience, I wind up stranded on the side of the road. I like being careful.
Postby ten2doyle102 » Mon Jun 10, 2013 3:50 pm
I was gonna a say motor mounts and trans mounts. Otherwise just run thru the bell housing bolts and maybe make sure that all your hoses are tight
Postby Yoshi » Mon Jun 10, 2013 4:05 pm
hoses. good idea
Postby Ryki » Mon Jun 10, 2013 5:10 pm
When did Yoshi and Tony swap?!?! Glad to hear you got it running, just go through hoses, caps, bolts, straps and areas where things generally fall off :P
Postby pr0craztinazn » Mon Jun 10, 2013 9:34 pm
Hose clamps, ground strap nuts, any fastener used to secure something to a bracket of some sort. That's really it for me.
Postby blasphemy101 » Wed Jun 12, 2013 5:58 pm
Yoshi wrote:At one point in time, this motor was 100% apart minus bottom end rotating assembly.
I'd check everything up top that I could, but hell I check the nuts on the rocker eccentrics a couple miles after a VA...
Postby Yoshi » Wed Jun 12, 2013 6:29 pm
VA?
lol I'll get right on checking those rockers :)
Postby blasphemy101 » Wed Jun 12, 2013 7:20 pm
Yoshi wrote:VA?
-lll._.- it was just an example. Has your motor fallen out yet?
Postby Yoshi » Wed Jun 12, 2013 7:31 pm
I checked out some of the driveline bolts yesterday and they were all tight. Visual inspection shows everything else on the engine is still there but I'd like to get a wrench around everything. Sadly, we are expecting a megastorm tomorrow so I can't get to it anytime soon. boo.
Postby M20_fever » Wed Jun 12, 2013 8:33 pm
VA=Valve Adjustment. Confusing for someone who lives in VA, lol.
Postby Yoshi » Wed Jun 12, 2013 8:42 pm
or is a veteran.
Postby blasphemy101 » Wed Jun 12, 2013 9:07 pm
Neither of those things have to do with rocker eccentrics :P
Postby M20_fever » Thu Jun 13, 2013 4:12 am
eh? How are rocker eccentrics not directly related to valve adjustment? :?
