Choke issue when on tick-over.
e30 baur
Post by e30 baur » Thu Aug 28, 2014 7:33 am
I have a 1984 323i and recently got a few bits sorted including timing belt, warer pump, etc. on a cold start the choke results in the engine revvi g at about 1400. Every 2-3 seconds it drops to 900 and then goes back up again. Any idea what is causing this. When the engine is warm it idles sweetly at about 850 constant.
Sent from my GT-I9505 using Tapatalk
Re: Choke issue when on tick-over.
Post by Yoshi » Thu Aug 28, 2014 11:09 am
Vacuum leak. Almost always a vacuum leak SOMEWHERE.
Post by M20_fever » Fri Aug 29, 2014 3:17 am
Could be failing ICV, I don't recall if 323s had them, or the cold start injector?
