Rear axle boot
Re: Rear axle boot
Postby M20_fever » Thu Feb 26, 2015 3:52 pm
lol speed bumps. I have to make detours around speed bumps over about 2" tall. I don't daily my car. Track prepping it has made it less than ideal for street duty.
Re: Rear axle boot
Postby 87e30 » Fri Feb 27, 2015 5:25 pm
daily driven - IMG_20150226_182718996.jpg (75.03 KiB) Viewed 1512 times
Re: Rear axle boot
Postby Ryki » Tue Mar 10, 2015 12:10 pm
Bigger wheels won't help the height of the car, you'll have to put smaller tires and end up with the same overall diameter >.> I would suggest against the .55, they have next to no drop whatsoever.
Re: Rear axle boot
Postby 87e30 » Tue Mar 10, 2015 12:35 pm
Ryki wrote:Bigger wheels won't help the height of the car, you'll have to put smaller tires and end up with the same overall diameter >.> I would suggest against the .55, they have next to no drop whatsoever.
Sure they will... Haven't you seen my other car? ;-)
Re: Rear axle boot
Postby Ryki » Tue Mar 10, 2015 12:49 pm
Dun lost it..
