The Rust Project
Re: The Rust Project
Postby Ryki » Sun Dec 30, 2012 4:20 pm
I feel like your car is the actual test subject, with how you put all the photos :P
Postby Yoshi » Sun Dec 30, 2012 4:23 pm
lol NAY!
Postby Yoshi » Fri May 17, 2013 12:31 pm
Figured I should update this.
SHIT AIN'T RUSTING
I need to research but I think the big issue here is that cars are electrostatically charged. You have the engine constantly shoving voltage/amperage/whatever through the chassis and that helps the oxidization process. Since my piece of metal just sits on some grass, only the exposed areas are rusting. Everything painted is just fine.
I really don't feel like shoving a trickle charger on it. Any suggestions?
Postby M20_fever » Fri May 17, 2013 2:08 pm
zip tie it to the bottom of your car.
Postby Yoshi » Fri May 17, 2013 4:04 pm
I'd want to weld it there. So the electricity conducts better. Not sure I want to do that with my DD though lol.
Postby M20_fever » Sun May 19, 2013 5:13 am
Drill a hole in the plate and bolt it to the sub frame, or trans support?
Postby AustinR » Sun May 19, 2013 6:06 am
I guess it could be the electricity, but I kinda doubt it. My only real reasoning here is think about the tailgates of trucks. Why would those rust? They shouldn't be grounded at all. I think it has more to do with moisture getting in places and sitting there for extended periods of time as well as the insane amount of abuse that cars are put through.
+1 for somehow fastening it to your car.
Postby Ryki » Sun May 19, 2013 9:24 am
+1 for rusty cat tail
Postby 87e30 » Sun May 19, 2013 10:28 am
Rusty penis welds?
Postby Yoshi » Sun May 19, 2013 3:03 pm
AustinR wrote:I guess it could be the electricity, but I kinda doubt it. My only real reasoning here is think about the tailgates of trucks. Why would those rust? They shouldn't be grounded at all. I think it has more to do with moisture getting in places and sitting there for extended periods of time as well as the insane amount of abuse that cars are put through.
Metal man. It's all mounted together so the whole body has SOME current running through it the whole time the truck is on.
Postby M20_fever » Mon May 20, 2013 3:16 am
I dunno, you won't (shouldn't) see any kind of voltage in the chassis even with a high end multimeter. Honestly I think it just needs more salt/moisture to really get close to what an actual DD in the rust belt sees.
Postby Yoshi » Mon May 20, 2013 11:10 am
I doubt you'll see any actual current in the chassis. There's too much metal for that. But think about it. Engine ground straps go to the frame rail, spark plugs ground through the block. All the ECU stuff tends to ground to the chassis. So the current has to run through the chassis either to the ground or back to the neg terminal of the battery. It's proven that even minute amounts of electricity will accelerate rusting. I think if it were high current, you'd see much more rust.
Postby Yoshi » Mon May 20, 2013 11:23 am
http://water.me.vccs.edu/concepts/corrosioncauses.html
influenced by many water characteristics, by the metals used, and by any stray electrical current.
The site also mentioned low ph things like vinegar and such to speed up rusting. I'd like to find a passive way to encourage "stray electrical currents" in the metal and maybe spray it down now and then with something mildly acidic.
Postby M20_fever » Mon May 20, 2013 9:50 pm
Spraying it with vinegar isn't exactly simulating real world driving conditions. Hook a 9v battery to it?
Postby Yoshi » Mon May 20, 2013 11:24 pm
I was thinking more salt water. Vinegar is expensive :)
Return to “Body and Interior”
