Spring rate master list
AntiSpam:No
Post by M20_fever » Fri Mar 18, 2011 10:00 pm
Some info copied from e30tech.com: http://www.e30tech.com/forum/showthread.php?t=40472
Spring---------------------Front(lb/in.)------------------Rear(lb/in.)
Stock 325i*-----------------------106-------------------------245
Stock 325is*----------------------118-------------------------265
Stock 325ix*----------------------106-------------------------308
Stock M3*-------------------------114------------------------314
Stock M3--------------------------140------------------------250
Dinan Sport-----------------------172-------------------------300
H&R OE Sport---------------------180-------------------------380
H&R Sport-------------------------180------------------------380
H&R Sport (29664)---------------200--------------------------285
H&R Race-------------------------315------------------------ 570
H&R Coilovers***----------------340--------------------------380
Eibach Pro-Kit--------------------114 --------------------------280-326 progressive
Eibach Race----------------------160--------------------------445
IE SIII----------------------------315--------------------------570
Koni Coilovers-------------------342----------------------------407
Cosmo Coilovers----------------450-----------------------------560
Tokico----------------------------165--------------------------265
TMS J-Stock**-------------------680--------------------------1026
Alpina(est.)---------------------~200-------------------------~350
FK 60/60 cup kit-----------------379----------------------------379
Vogtland Standard***--------115/197---------------------------360
Vogtland CS***---------------137/200--------------------------400
Vogtland--------------------------225--------------------------360
Intrax-----------------------------126--------------------------250
King Springs "Low" -------- KDFL-01 220----------------KDRBL-14 440
*= Sourced from June, 1987 article of "Motor"
**= Alternate rates available
***= M3 Application
antil33t
AntiSpam:No
Re: Spring rate master list
Post by antil33t » Wed Mar 30, 2011 7:59 am
King Springs "Low"
Front KDFL-01 220 lbs/in REAR KDRBL-14 440lbs/in
AntiSpam:No
Post by M20_fever » Wed Mar 30, 2011 10:41 am
thanks, I'll update this tonight.
antil33t
AntiSpam:No
Post by antil33t » Wed Mar 30, 2011 7:50 pm
I emailed king springworks australia, and asked... and got the reply in a few hours _b
Probably not a useful fact for any of you americans, but the dudes from this side of the world may find it.
Cause' I couldn't find the rate on their site anywhere.
AntiSpam:No
Post by M20_fever » Thu Mar 31, 2011 12:29 am
updated first post, thanks!
7pilot
AntiSpam:No
Post by 7pilot » Fri Mar 23, 2012 12:05 pm
Does anyone know what the rates are for the E30 M3 H&R race springs?
TMS have them listed in a separate (more $$ kit) offer. Or are they trying to be clever?
m
AntiSpam:No
Post by Yoshi » Fri Mar 23, 2012 12:48 pm
I don't know of anyone who has purchased them. Try S14.net or calling up the shop themselves. Report back!
AntiSpam:No
Post by M20_fever » Fri Mar 23, 2012 6:34 pm
I didn't see the race springs listed separately for the M3 on TMS website? There is an M3 suspension kit, but the difference there is the shocks not the springs. Far as I know e30m3 and regular e30 H&R are one in the same.
AntiSpam:No
Post by AustinR » Sat Mar 24, 2012 12:52 am
I can't imagine them being different. I had m3 springs on my 325i with billie sports. They're just ever so slightly shorter, not much. My point is the springs are interchangeable so they're *probably* the same.
AntiSpam:No
Post by Ryki » Tue Mar 25, 2014 9:54 am
Did some research on the Eibach Pro kit I picked up for super cheap, found this from someone who has a E30 and works at Eibach:
"Regarding the rates posted above (Eibach Pro-Kit): Those Pro-Kit rates are off. Front is 114 linear, Rear 280-326 Progressive."
Gentleman was referencing the spring rate master list.
AntiSpam:No
Post by Yoshi » Tue Mar 25, 2014 10:49 am
well this master list is copied anyway lol.
AntiSpam:No
Post by M20_fever » Tue Mar 25, 2014 12:51 pm
Fixed, thanks!
